View unanswered posts | View active topics It is currently Tue Nov 21, 2017 5:00 pm
Reply to topic  [ 2 posts ]
 Carb jet setting for high altitude
Author Message
Post Carb jet setting for high altitude
Hi every one .
Please can some one tell me where to get specs on the sizes of different jets for high altitude? I am at 1500m but do intend traveling at the coast now and then, probably a 50/50 scenario. Southern Africa is my playground :lol:
Have seen a choice of the following jets available to purchase for the Zenith 36;
Idle Jet 55 Carburetor Zenith NDIX 36 7001084051-55
Idle Jet 60 Carburetor Zenith NDIX 36 7001084051-60
Main Jet 125 Carburetor Zenith NDIX 36 7001084041-25
Main Jet 135 Carburetor Zenith NDIX 36 7001084041-35
Main Jet 140 Carburetor Zenith NDIX 36 7001084041-40
Idle Air Jet 110 Carburetor Zenith NDIX 36 7001084071-10
Idle Air Jet 130 Carburetor Zenith NDIX 36 7001084071-30
I have also noticed the following concerning my two carbs;
Are both carbs supposed to have the same jets? Because one has Idle Jet 55 and the other Idle Jet 60 , Main Jet 135 the other Main Jet 140 and the choke disks are also different, one is a No.2 and the other a No.6 i.e. one has small holes and the other bog holes (one of each circled in red).
Thanks in advance
Tue Nov 14, 2017 10:25 pm
Profile
Post Re: Carb jet setting for high altitude
Main Jets 135 for 800-1500meters, 130diameter 1500 to 2000meters and 125 diameter 2500 to 4000meters
mount at your´s with slow running jet 55
and 130 slow running air jets
( 140 Main jets only with 60 slow running jets and 110 slow running air jets up to 1200meters)
The starter air disc no 2 has the big hole and is corsale to regulate( short way). Mount no 5 or no 6
There are different kinds of throttle cambers too, different drill holes, throttle flaps and side sealings, also different throttle lever- high and low :wink:
Wed Nov 15, 2017 2:10 pm
Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
