fixed my leaking motor
Engine troubles? Try here.
Hotzenplotz
Austria
Post by Hotzenplotz » Wed Jun 13, 2018 3:44 pm
Just wanted to share some recent events
My Pinz didn't pass the annual technical inspection; oil leaking from several places.
First I built an engine stand from a central tube a mate had lying in his shed
enjoyed the sunshine and broke down the engine.
the leaks were caused by broken O-rings at the oil return pipes and brittle rubber seals at the push rod pipes.
When I replaced the oil pan gasket I swapped the 8.8 quality hex bolts for 10.9. Gaskets at oil intake and filter flange also came new
A ratchet belt is helpful for mounting cylinder heads alone.
Now the motor is running in the testbed and will be reinstalled this weekend
https://youtu.be/71A3ZHKUDEg
Albert
63rover
Re: fixed my leaking motor
Post by 63rover » Fri Jun 15, 2018 6:46 am
Looks like a job very well done. Thanks for the ratchet strap idea. I'll make use of that one.
Cheers, Clive
McCall Pinz
Post by McCall Pinz » Sun Jun 17, 2018 11:16 pm
That didn't even sound very loud without the muffler!
eat, sleep, Pinzgauer
Hotzenplotz
Austria
Post by Hotzenplotz » Mon Jun 18, 2018 1:40 am
The engine has returned into the truck and has ceased marking its territory.
MOT is scheduled for Wednesday. Fingers crossed I'll be back on the road then...
Albert
