Im having an issue i cannot get the timing mark to come any closer than about 40ish mm before the pin
when i turn the distributor in the direction it needs to go it hits the fan shroud.
i looked through the manual (page 36 sction A ) and it says its possible to move the distributor driveshaft a few teeth over but i wanted to check with you guys to see if i am correct ??
