Carbs gushing gas
Engine troubles? Try here.
OhioPinz
Carbs gushing gas
Post by OhioPinz »
After 7 years of zero problems, my carbs both started gushing gas out the sides. It was running fine before this. Did both my float valves just give up?
OhioPinz
Re: Carbs gushing gas
Post by OhioPinz »
Turns out my cover plates for the jets were simply loose.
EmbarkChief
Post by EmbarkChief »
It's so nice when the fix turns out to be simple!
-1972 710M
BELied
Post by BELied »
While you're there: you may want to replace the carb gaskets when you take off the covers. They're just o-rings that you can find at any hardware store and will save you from future fuel spewage.
