torquing carb to manifold
Posted: Mon Feb 22, 2016 6:51 pm
by audiocontr
Is there a need to semi tighten all 4 nuts, then torque down further in a certain pattern? Are the unique pinz washers required?
Re: torquing carb to manifold
Posted: Mon Feb 22, 2016 6:57 pm
by Buzz
Not that I am aware of, and I have pulled and rebuilt my carbs before. The only thing I would recommend is some mid strength loctite. They seem to vibrate loose pretty easily if you don't use a little loctite and that will play all heck with your carb synchronization.
Posted: Mon Feb 22, 2016 8:45 pm
by oilcan
only thing i did was to tighten down in a diagonal pattern loosely and then go back and tighten down in a rotation, to help make sure they leveled out as much as possible. the bolts vibrate loose very easily.
Posted: Sun Feb 28, 2016 10:50 am
by pinzinator
Yes, use the washers!
