Carbon fouling my carbs?
Twin Pinzies
Post by Twin Pinzies » Sun Apr 10, 2016 11:06 am
When I was swapping my main jets last summer, I noticed that the internals of my carbs were dark and sooty. I'm pretty sure that a carb in good condition should be clean and shiny since it should only deal with air and fuel.
Is this a symptom of bad piston rings?
Re: Carbon fouling my carbs?
Post by rmel » Sun Apr 10, 2016 12:10 pm
Any backfiring when starting or under any driving conditions?
Do you see any carbon deposits in the Air Intake hood Group # 1-35-15?
See anything in there might backfiring on you at times, if you do
might be a rich or bit too far advanced.
Rescue Pinz: 73' 712M
Texas710
Post by Texas710 » Sun Apr 10, 2016 8:07 pm
I was thinking timing as well.
What about a weak intake valve spring or possibly wearing valve seats...
Post by Jim LaGuardia » Sun Apr 10, 2016 10:12 pm
They all get dirty. Very normal, the crank case vents into the air box, the more blow by, the faster the sooty build up.
Cheers, Jim LaGuardia
"Arch Magus of Machines."
Twin Pinzies
Post by Twin Pinzies » Sat Jul 09, 2016 10:32 am
Thanks for the replies guys.
Could it also have anything to do with 10% ethanol in my gas? A friend of mine said that his snowmobile did that when he started using ethanol gas.
