View unanswered posts | View active topics It is currently Thu Dec 14, 2017 10:55 am
Reply to topic  [ 4 posts ]
 712 m popping at exhaust
Author Message
Post 712 m popping at exhaust
I just recently acquired my pinz and changed all the fluids and washed the motor out and forgot to cover the distributor and then it started popping then wouldnt start like it was out of timing this morning i uncovered the cap and there was moisture in it so i sprayed wd 40 in it and it got better starts right up now but still pops at idle not when in motion has great power it does have a petronix ingnition and of course all that popping caused my muffler to crack open a little so i have to fix that what do u guys recomend from here is the dizzy still have moisture in it thats why its still popping at idle
Sat Apr 01, 2017 1:12 pm
Profile
Post Re: 712 m popping at exhaust
Not surprising. They run weird until warmed up. Make sure you're giving it proper choke, and be mindful of ethanol gas. You may need to clean out the carbs. warm it up and check the popping
Beyond that, you may have a worn out elbow in the distributor vacuum line. Its not pure vacuum, so do NOT replace with a new one... there is a restriction ball in there that keeps the line at a low enough vacuum to remove condensation, but not enough to pull oil.
You may need to adjust your carbs
You may need to check your timing
You may have exhaust manifold linkages that have come loose, creating the popping
All and all, it could be a lot of things, but don't get worked up over it. These trucks have gremlins. Chasing little things may create bigger things
_________________
(2) 1968 Haflingers 1 For Sale
1978 GMC Palm Beach
1979 Mini Ranger For Sale
1986 Corvette For Sale
2001 F250 Diesel and trailer
Company Cars
2017 MKT
2018 F-150
Sat Apr 01, 2017 3:14 pm
Profile
Well I am new to the pinzgauer and forum but have managed to get some repair time behind me now. I had a very similar problem, spending hours dealing with the carburetor and various things as mentioned above. Two things promptly fixed it: a new distributor cap and I adjusted the petronix gap to the recommended distance. It was a little wide. started right up, no backfiring.
So now I can say I have officially given anecdotal advice on the forum.
_________________
75 710K
New owner
Sat Apr 01, 2017 4:20 pm
Profile
Thanks guys for the responses as you know when its youre first is always a puzzle putting piecs together i will start with the easiest which is replace the dis cap and go from there like i said it ran fine on thursday it was just after the clean up that it started acting up
Sat Apr 01, 2017 5:55 pm
Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
