View unanswered posts | View active topics It is currently Thu Dec 14, 2017 11:01 am
Reply to topic  [ 3 posts ]
 Spring maintenance tip
Author Message
Post Spring maintenance tip
Hi all
Just a preventative maintenance tip. When doing your spring maintenance (for those of us who are seasonal) check the condition of your fan shroud mount. There is an aluminum spacer attached to the shroud at the mounting point. Mine must have developed multiple stress fractures over the years and it finally let loose. Not sure if it was all at once though, but it's not obvious unless you look for it. While changing my fuel filter I budged it loose and realized the only thing holding my fan shroud in place was the clamp pressure from the tin. All four corners has cracked off and she was free floating!
Happy trails,
Dave
_________________
Sat Apr 29, 2017 9:16 am
Profile
Post Re: Spring maintenance tip
Nice catch on that one!
Mine will be out of hibernation this coming weekend - excited!
_________________
72 Pathfinder
75 710M 2.7i
94 350GDT
96 350GDT Worker
Sun Apr 30, 2017 7:30 am
Profile
Sweet. Should be an easy spring prep given that yours is pretty much showroom new!
_________________
Sun Apr 30, 2017 7:37 am
Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
