View unanswered posts | View active topics It is currently Thu Dec 14, 2017 10:45 am
Reply to topic  [ 6 posts ]
 Ponz timing help needed
Author Message
Post Ponz timing help needed
What is the correct degrees for timing on a 73 pinz and rpms setting
Tue May 09, 2017 8:16 am
Profile
Post Re: Ponz timing help needed
it depends ....
first
ensure that the distributor rotor "clicks back" to ensure the dynamic adjustment works
if not, disassemble and grease /fix
then
set the points to 0,4 mm
do a static setting using a test-lamp
once you got the tin humming, rotate the distributor until it "sounds right" ...
_________________
Albert
Wed May 10, 2017 6:50 am
Profile
Do you have points or Pertronix ?
BTW this is covered in the operators manual (around page 150 iirc) if your truck is stock and on Scotts site if Pertronix has been installed.
_________________
Ed
75 710K (sold)
06 2WD Ural Patrol (sold)
69 2WD Rokon Trailbreaker 4 sale
A few Honda Trail 90's (all sold)
Wed May 10, 2017 10:05 am
Profile
Yes sorry it does have the petronix civilian upgrade
Wed May 10, 2017 2:48 pm
Profile
Time the pinz setting the ignition 3-5 degrees BTDC. 850 - 950 rpm.
https://support.expeditionimports.com/hc/en-us/articles/216824848-EICSB102-Pertronix-Install
https://support.expeditionimports.com/hc/en-us/categories/201794987-Pinzgauer-Tech-Support
_________________
Ed
75 710K (sold)
Thu May 11, 2017 9:59 am
Profile
Thanks guys for all the quick responses
Thu May 11, 2017 11:00 am
Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
