Ponz timing help needed
Posted: Tue May 09, 2017 9:16 am
by Rookie
What is the correct degrees for timing on a 73 pinz and rpms setting
Re: Ponz timing help needed
Posted: Wed May 10, 2017 7:50 am
by Hotzenplotz
it depends ....
first
ensure that the distributor rotor "clicks back" to ensure the dynamic adjustment works
if not, disassemble and grease /fix
then
set the points to 0,4 mm
do a static setting using a test-lamp
once you got the tin humming, rotate the distributor until it "sounds right" ...
Posted: Wed May 10, 2017 11:05 am
Do you have points or Pertronix ?
BTW this is covered in the operators manual (around page 150 iirc) if your truck is stock and on Scotts site if Pertronix has been installed.
Posted: Wed May 10, 2017 3:48 pm
by Rookie
Yes sorry it does have the petronix civilian upgrade
Posted: Thu May 11, 2017 10:59 am
Posted: Thu May 11, 2017 12:00 pm
by Rookie
Thanks guys for all the quick responses
