View unanswered posts | View active topics It is currently Thu Dec 14, 2017 10:58 am
Reply to topic  [ 9 posts ]
 Is non matching numbers common on Swiss Pinz's?
Author Message
Post Is non matching numbers common on Swiss Pinz's?
Hi,
I've recently noticed that my engine is non numbers matching to my 72 710m tub. Did the Swiss change them out rather than rebuild? Maybe this was common practice, or is mine an unusual situation?
Just curious mostly, but was a bit surprised.
thanks, Dave
_________________
Wed May 10, 2017 10:52 am
Profile
Post Re: Is non matching numbers common on Swiss Pinz's?
When the Swiss refurbished trucks in the '90s, parts didn't always go back to the original truck..My '71 710m had a driver's door with a different dataplate than the body's plate. So it is possible a body could be put on another chassis
_________________
Wed May 10, 2017 11:47 am
Profile
From what I've been told, this is a problem common to former military vehicles of most varieties, including U.S. Whether because a part has been robbed off a scrapped vehicle or one awaiting parts, or simply from installation of factory replacement parts, it seems to be pretty normal.
The reason it doesn't happen so much in the civilian world is probably because it's rare to have multiple versions of the exact same vehicle being serviced together. Even the colors match! Plus, your average civilian owner would call the cops.
_________________
Wed May 10, 2017 2:55 pm
Profile
Thanks for the reply's, sounds reasonable. My truck was redone in the 90's so that'll be what happened.
Dave
_________________
Thu May 11, 2017 8:38 am
Profile
I don't know the legal status in the US but in Europe the VIN has to be engraved or stamped into the chassis. Any label like the metal plate next to the driver's seat is just meant to make the number easily spottable. If there are discrepancies the VIN on the frame is considered valid.
_________________
Albert
Mon May 15, 2017 1:56 am
Profile
Where is it on a Pinz?
_________________
72 Pathfinder
75 710M 2.7i
94 350GDT
96 350GDT Worker
Mon May 15, 2017 8:13 am
Profile
i have a 712. it has the chassis number on the main tube, between 2nd and 3rd axle.
guess it will be similar with a 710
_________________
Albert
Mon May 15, 2017 8:47 am
Profile
Never seen it but have not looked either
Will check tonight
Thx
_________________
72 Pathfinder
75 710M 2.7i
94 350GDT
96 350GDT Worker
Mon May 15, 2017 10:42 am
Profile
On my 712 it is on the driver's side, hidden behind the exhaust shield. It is a removable part (once the chassis is disassembled!) unlike a typical frame stamp. In California, they only require two separate matching VIN numbers so they only needed to look at the door and floor plates!
_________________
Mon May 15, 2017 11:07 am
Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
