The Portal Hub: All things Pinzgauer, Haflinger, Volvo 303 and more.
From Vince Sweeney: You have arrived at the original "Real 4x4's" Forums, founded in 1999.
The forum isn't free for me to keep up. Donations accepted securely with Paypal.
View unanswered posts | View active topics It is currently Thu Dec 14, 2017 10:58 am
Reply to topic  [ 6 posts ]
 too much centrifugal advance?
Author Message
Post too much centrifugal advance?
I am timing the pinz and the only way to get good power below 1800 rpm is to advance it to the point where at high rpms I get pre-ignition.... as if the advance was either not opening soon enough, or advancing too much...
I took the distributor apart and everything is clean and smooth in the interior.
Also, water kills my ignition.. how do I check for that vaccuum valve in the line elbow?
Thank you,
Jeronimo
_________________
Jerome
CRJ Driver
Mon May 15, 2017 11:06 am
Profile YIM
Post Re: too much centrifugal advance?
One of you advance springs may have rusted and broke, so it advances too soon. You need to pull the dizzy and remove the shaft as the springs are underneath. While the stock setup was pretty waterproof, most civi conversions are not very well protected. The "vacuum" line had just a tiny pinhole to barely move air. In the sealed stock configuration this made sense as it would slowly evacuate air and draw oil up the shaft. Vacuum is useless beyond that design. Get a SSI if you want water resistance; no high voltage is exposed to water beyond the spark plug wire boots.
_________________
Mon May 15, 2017 11:13 am
Profile
I used a small metal ball valve as my "restrictor". It took some time to find the proper setting... too low and moisture condensed within the cap. Too high and it caused the RPMs to rise. My best advice is just slightly opened
_________________
(2) 1968 Haflingers 1 For Sale
1978 GMC Palm Beach
1979 Mini Ranger For Sale
1986 Corvette For Sale
2001 F250 Diesel and trailer
Company Cars
2017 MKT
2018 F-150
Mon May 15, 2017 11:39 am
Profile
Jim, if I could afford the SSI, I would do it. Just too expensive.
I know I can waterproof the civi ignition, just need to figure out why it is not working ok with the original distributor. I have a friend with a Pinz, I will swap dizzies one of these days.
Based on what I experience, the problem would be the opposite, the weights open too late or too much. Again, it is smooth and clean inside...
Regarding the vacuum line, maybe an aquarium aireator valve will do the trick!
_________________
Jerome
CRJ Driver
Mon May 15, 2017 3:17 pm
Profile YIM
Watch out for heat melting plastic restrictions
_________________
1978 GMC Palm Beach
Company Cars
2017 MKT
2018 F-150
Mon May 15, 2017 4:22 pm
Profile
It is not unusual to find the Pinz dizzy with the weights frozen in place, too. Rust can cause either to happen - stuck weights, or rusted through springs.
_________________
Mon May 15, 2017 11:05 pm
Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
