View unanswered posts | View active topics It is currently Thu Dec 14, 2017 10:52 am
Reply to topic  [ 2 posts ]
 Vacuum gauge reading
Author Message
Post Vacuum gauge reading
What would be considered a normal reading on a vacuum gauge when connected to the intake? How steady should the needle be on a good engine?
Fri Sep 22, 2017 10:04 am
Profile
Post Re: Vacuum gauge reading
Assuming your vacuum gauge is calibrated in Inches of Mercury, at idle 800 -- 1,000 RPM should be about -17 to -20 InHG.
MAP readings are going to be strongly dependent upon load and RPM (and leaks).
_________________
Puller: 710K 2.7L EFI
Fri Sep 22, 2017 1:48 pm
Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
