Could be simple could be a whopper -- need more info to help.
Did the engine also run really crappy, skipping, needing some
throttle to keep running? And BTW don't run the engine at this
point W/O figuring out what's wrong....
If you have the flex connection between the headers to heat
exchanger, take a look at the flex pipe and see which (or both)
may be wet with oil, e.g. associated with Cyl 1,4 or Cyl 2,3. If
both then I'd be suspicious of a problem effecting all cylinders
as per below, if one header only then you might be looking at
a particular cylinder that has a problem.
Check your Plug wires, if you have the stock plugs and wires
they may look bullet prof but they can fail. Again did it run
poorly e.g. running on 3 cylinders?
Check to see if your distributor came loose and is freely rotating,
gross improper timing can "pull" excessive oil into the chamber
and out the exhaust port -- been there done that
Y'd be
lucky if this is your problem. And if you have PinzSSI a timing
reset is very easy.
If timing is good, then I'd pull all plugs and inspect them for
color, which is oily, which is dry and carbon. Get a Borescope
down each and visually inspect the tops of the Pistons and wall
to the extent possible. If that looks good I'd then follow up with
a compression test on each cylinder, looking for an outlier.
See where that takes you in terms of getting more observations,
if this is all new to you find a friend who can help.
Good luck,
