Diagnosing Fuel Leak - Help Please
Posted: Sun Jun 06, 2021 8:56 am
by Hersir
I'm hoping the power of the Pinzgauer hive mind can help me diagnose a fuel leak.
Yesterday I was driving my 710M and noticed a strong smell of gas. When I parked, I saw a steady drip of gas coming off the undercarriage close to the center tube across from the fuel tank. There was no leaking before I started driving and it stopped about 10 minutes after I parked. The filler tube area looks dry which made me think that it might be a sending unit seal, or possibly the fuel pump. The truck seemed to run fine at idle and at speed. I am not a mechanic but like to do the work I can do with basic tools. I'm trying to figure out if this is something I can fix with some new seals without dropping the tank or if I need to take it in to a shop.
Thanks all.
Re: Diagnosing Fuel Leak - Help Please
Posted: Sun Jun 06, 2021 10:47 am
by rmel
Given the amount of fuel you are leaking you should be abler to spot the problem.
I'd remove the seats and Dog house, air filter and air intake manifold on top of the carbs.
This will expose most of the areas of interest. Then just get down to some basic inspection.
Attempt to try to identify any wet fuel spots with the engine OFF. Look around the base
and tops of the carbs, sides, hoses and fittings. It could be anything from a bad fuel line
to the carburetor bowls overfilling, or a fuel pump leak. Given the amount of fuel you seem
to be leaking you will probably spot the problem pretty quickly.
Posted: Sun Jun 06, 2021 12:45 pm
by Hersir
Thank you, I did just that and it became pretty clear that it was the brass outlet from the fuel pump. It wiggled in and out easily and when I turned over the engine it starting leaking from that connection immediately. I cleaned the brass fitting, sanded the exterior lightly, and used JB Weld to glue it back in place. We'll see if this does the trick. Worst case, I'll be replacing a fuel pump. Thanks again.
Posted: Sun Jun 06, 2021 1:25 pm
by pcolette
Your method of repair should work just fine. I've done that a few times myself.
- IMG_4408.jpeg (423.41 KiB) Viewed 2174 times
Posted: Sun Jun 06, 2021 8:53 pm
by ChickenPinz
Hersir wrote: ↑Sun Jun 06, 2021 12:45 pm
if the epoxy repair doesn't work, then you can get just the top section of the fuel pump as a replacement part. As a bonus, that section includes the two flapper valves that get tired over time and cause a vehicle to be hard to start after sitting for a few weeks. Change that part and she'll start right up even after several weeks of sitting idle.
Others have reported the epoxy fix works pretty well, and yours is certainly not the first to develop a leak at that insert location.
