Hard starting hot
Posted: Sat Jul 08, 2023 5:54 pm
by JimmyC
My Pinz takes a lot longer to start when it is hot. It starts instantly when engine cold regardless of air temp. Takes a bit of cranking when hot. Ideas?
Re: Hard starting hot
Posted: Mon Jul 10, 2023 9:05 am
by pinzinator
Heat may be affecting the coil.
Posted: Mon Jul 10, 2023 7:00 pm
by JimmyC
Did not think of that.
Posted: Tue Jul 11, 2023 1:28 am
by David Dunn
Check your charging voltage. If something's wrong with the voltage regulator or the alternatorr and gives out over 30 volts that will overheat your coil
Posted: Wed Jul 12, 2023 9:15 pm
by whitesik
What is the interval between starts? Long enough for the fuel to evaporate in the bowl in hot weather? Are you using the "choke" in hot weather; full? half? There are many variables.
