Oil dripping from pan
Posted: Wed Nov 15, 2023 12:18 pm
by ziegler
The oil pan gasket is good but there's oil coming from above the oil pan on the drivers side. It's not from the oil cooler, does anyone has any ideas. I changed the O rings and the gasket of the oil cooler thinking that would solve the problem but it didn't. Can it be the exhaust manifold gasket? Thank you. Zig
Re: Oil dripping from pan
Posted: Wed Nov 15, 2023 9:52 pm
by rmel
On the drivers side is the cylinder side so there are several possibilities.
But a pix of the area would help.
Posted: Fri Dec 22, 2023 6:40 pm
by Andre
Pushrod tube seals drying up. Or the oil return tube. Both use rubber beveled washers to seal against oil leaks. Make sure the valve covers aren’t weeping either.
