quick fixes on manifold to heat exchanger leaks?
Posted: Fri Sep 18, 2009 5:15 pm
Any suggested quick fixes on manifold to heat exchanger leaks?
I know that flex couplings are the long term fix, but wondering if there
are quick & dirty fixes that can be used until I can take time to remove
the manifolds and do the flex coupling.
With the official exhaust sealing rings at $28 each, has anyone used alternatives even as a temporary fix? Mainly wanting to reduce the exhaust leak & backfiring for a week or two until I can do it right.
I guess the other alternative is to find a way to do the flex coupling
without having to remove the manifold & grind the ring off. Is it
zizzz wheel hell to try to remove without taking the manifold off?
Any suggestions welcome! I hate smelling like exhaust anytime I crank/drive the pinz!
Have fun,
Alan
Have fun,
Alan
