top bolt on the starter , tough .
norcal pinz
Post by norcal pinz »
im having trouble removing the top bolt from the starter in my 710k i thought i had done this before but i guess not. I removed the wiring and the dipstick and the bottom bolt but the top one is such a tight squeeze i can barely get the wrench in there im thinking about cutting a wrench in half so i have room to swing it around? :roll: i broke it free i just cant turn it any suggestions would be handy .
710M 1972
710k 1974
buzzz
Post by buzzz »
Norcal Pinz I had the same problem. I bought a C shaped box end wrench at Harbor Freight, still had to gring it a bit but it worked great.
Cheers Buzzz
Try pulling the 2 mounting nuts off the slave cylinder and moving it out of the way :shock:
Then you can use any wrench, also loosen the lower nut to ease removal of upper nut :wink:
M Wehrman
Post by M Wehrman »
Jim said it,after 30 yrs as an auto tech,sometimes it's worth the x-tra time to take something else outa the way!
Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
milesdzyn
Post by milesdzyn »
Yeah I had no problems removing mine, Just took the whole body tub out of the way. :lol:
Miles
'73 Pinzgauer 712M
Profpinz
Post by Profpinz »
It takes a few minutes to remove the clutch slave....you don't even have to disconnect the line/hose, so it's simply a matter of re-bolting it back in place when you've finished.
or, you could use Miles's method! :roll: :D
http://www.ozpinz.com
norcal pinz
Thank you everybody, sounds like removing the slave is going to be the way to go! i wish i thought of that :lol:
710M 1972
710k 1974
