Heat riser flexible hose source
Engine troubles? Try here.
mockingbird812
Post by mockingbird812 »
Mine are deteriorated. I am looking for the one that goes from the exhaust system to the intake to warm the carbs.
Thank you.
Sam
'71 710K
Bruce Berger
Post by Bruce Berger »
Try Aircraft Spruce -
http://www.aircraftspruce.com
Do a search for "SCAT"
I just replaced mine and it's surprising how warm that heat riser duct gets idling in the driveway.
Bruce Berger
'72 Pinzgauer 710M 2.6i
mockingbird812
Thanks Bruce - that looks like it should do the trick. What diameter and length did you use and were you happy with the fit?
Sam
'71 710K
landy
I'm using flexible air intake tubing that...
Post by landy »
I got from Autozone. It's Spectre brand.
