Had a big backfire - I found out the airfilter was plugged and it was making the oil suck into the carbs - plus it was running rich then.
I started it up and BANG!!!
Well I opened up the muffler a bit..hmmm just wondring if i took it off if it could be welded.
Seems to be fairly heavy metal on the original - otherwise I will just buy a new one from EI
Muffler repair
muffler
kinda what I was thinking to
fixed here - good as old
So we removed her - cut the end out of her - cut a 9.5" - 3/16 plate and wired fed her in - the outer shell was a bit thin so I got some of the exhaust compound and lathered her on and tined it and a bit of hay wire and she good to go..for awhile anyway.
jer bear
jer bear
muffler
Well the haywire is there until the patch dries. It dries hard as nails, but I will just leave the wire there until it falls off probably.
I think I will probably order the part that changes the two exhaust ports to one port and then put a different muffler on then.
jer
jer
muffler links
These might be of interest
http://real4x4forums.com/PinzgauerBBS/v ... php?t=4759
scroll down to pics on that one
and
http://www.sdp-pinzgauer.org/html/muffl ... ement.html
and
