Fluid Change
Fluid Change
All,
I want to change all my oil and transmission fluids. what are most of you guys using. is there a chart somewhere with capacities.
Doug
Doug
Kind of depends on what your driving and where your driving it.
could be...
Chevron Delo® Gear Lubricants ESI 85W-140
Oil Capacities
spec- SAE 90 MIL-L-2105
Reduction Gearbox 2.30 liters
Diffs 2.00 l
Front Hubs 0.40 l
Transmission 2.30 l
Rear Hubs 0.35 l
Steering 0.45 l
spec- SAE 30 or 15W/50 or 20w/50
Engine 7.0 liters 6.5 liters @ OIL CHANGE
DOT-3 SAE-J-1703
BRAKES 4X4 500cc
CLUTCH 200cc
GEARSHIFT 400cc
could be...
Oil Capacities
Diffs 2.00 l
Front Hubs 0.40 l
Transmission 2.30 l
Rear Hubs 0.35 l
Steering 0.45 l
DOT-3 SAE-J-1703
BRAKES 4X4 500cc
CLUTCH 200cc
GEARSHIFT 400cc
Heck Jim, how do we know what his weather is like? Now if he’d let us know where he’s from..Jim LaGuardia wrote:Do not use multigrade gear oil, it is too thick in cold weather.
Doug listen to Jim he is a good source of knowledge.
Ed
I put a 12" piece on after the valve so I could reach into spots and keep the valve out in the open. Works exceptionally well. I also keep an empty 308 case to plug the hose end so the oil does not get all over the place, the valve is threaded and comes with a plug but with the hose it does not do much good.
