How much oil should it burn?
Posted: Sun Apr 18, 2010 12:15 am
by totaljoint
I have put about 1000mi on my 712 since I got it 4 months ago, and have put in 4-5 quarts of oil over that period. I'm adding one quart for every 30 gallons of gas or so.
It doesn't smoke when running, and not a drip to be found under the engine. Really, none!
Jim L. did a compression test on it just prior to my possesion, it passed well (around 156-158 to my memory).
How much oil do these engines burn on average and when should I worry?
Ed
Posted: Sun Apr 18, 2010 11:22 pm
My 712W did that for YEARS (well, at least the first 5 that I had it) at about the same consumption - I put in a quart every other fillup. I went to replace the intake valve seals and there WASN'T ANY! But even after adding seals, the oil consumption never changed. It was not until Jim L. rebuilt it that it got less thirsty, probably something in the neighborhood of a quart every 2-3,000 miles.
Jim does good work!
On the other hand, my 710M doesn't need oil added between yearly oil changes, and it is a completely stock engine.
Posted: Mon Apr 19, 2010 7:03 pm
by M Wehrman
Sometimes changing to another brand of oil helps. Learned this on several vehicles in the past,Castrol seems to work best for me. On a hard run up the mountains and back,pushing hard I will use 1/2 qt in 300 mi.
Mark
Posted: Tue Apr 20, 2010 7:43 pm
by Peresh
Castrol SAE 30!!!! for me as well. I'm surprised that different brand oils work differently. I thought they were all the same but not.
I picked up Wagner High Detergent SAE30 awhile back and it was burning quicker. Also I added Lucas oil additive one quart to 5 quarts at every oil change. Lucas made it run even smoother and cuts down oil consumption.
But then again, I'm a fanatic about keeping the Pinz in top condition.
Posted: Wed Apr 21, 2010 6:08 pm
by karoja
My 712 barely consumes oil. However, we use SAE40 instead of SAE30 down here.
Posted: Fri Apr 23, 2010 6:28 am
by stiffler4444
Luckily, my 72 710 burns no oil nor does it leak any...however, in my other vehicles, Castrol has always burned the least.
Posted: Fri Apr 23, 2010 6:59 am
by totaljoint
Glad I'm running Castrol 30HD. Would hate to see how much I burn with something else.
