I tried to reinstall the two bolts that backed out from the oil pump. I found that the first one has the threads stripped out from the block. The one that stripped is the one of the holes near the gears with the locating sleeve. Also, the other hole appears to have threads intact, but they seem a little loose till the bolt bottoms out.
Does anyone have a recommended/preferred thread repair for the aluminum block?
Engine Thread Repair
Kimball
1979 712M
1979 712M
