50 gallon reserve tank - The process
Well here is a pic of the tank I got from Cabelas...she's 50 gallons and it will fit perfectly between the support braces in my K for the shelves in the back...I need to add about a 4" piece to the height and a bar across the middle to support the tank.
some details
the back with all the shelves taken out.
With her in there
So today my original is getting welded back together and I will start on this one.
CONCERNS: any help would be appreciated here.
1 - Venting and filler to go on the back end or side? I was thinking the back end for filler - side for vent (less fumes).
2 - Static collector: - do I ground before the shut off switch or after.
3 - should I mount it on rubber?
Jer Bear
some details
With her in there
Jer Bear
So she is in and all I have left is to run the fuel line and put the three way fuel rod in.
Should have her completed next week sometime.
Here are a few pics
Had to raise the brackets about 2" to clear the tank so I can mount the shelves back on later.
I ran some perforated angle for support for the sides and the bottom. I put a 3/4" piece pf plywood and put some rubber on it. I also put some rubber on the upper bracket to avoid rubbing.
I ran some perforated strapping (plumbing kind) over the top and underneath to hold her in place....also some of the angle on both ends and added some padding so she can't slide anywhere.
This is how she looks from outside and a close up.
I will take some close up pics of the hoses and the wiring tomorrow ok.
Jer bear
Here are a few pics
Jer bear
Nice work!
looks really good- where you headed with that much gas, Jer?
nice rack!
How'd you mount the feet of those Thules to the Pinz roof?
Skeej
Skeej
Nice rack setup Jer. The Thule Tracker rail system is a great option for the Pinz and is much cleaner IMO than a gutter-mount tower install. My recommendation for others looking to do this type of install on a K is to mount the rails as far outward as possible (I mounted mine a rail-width out from the outermost roof rib) in order to gain the greatest support from the walls of the Pinz. It's also worth noting that the 54" Thule rail can be fitted to straddle the rear and center support members of the body increasing the load capacity even further.Jerbearyukon wrote:Yeah should be able too put about 400 pounds if we go easy on the road....
because the rack is there I can put some in and some around it and spread out the weight a bit...always room inside in a tarp too.
Jer Bear
