Muffler flange nuts
Muffler flange nuts
Am going to use stainless bolts when I refit my new stainless muffler but reluctant to use Nyloc nuts due to the heat. Should I use spring washers or epoxy or something else?
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
- ScottishPinz
Bit worried about spring washers after seeing this:
http://www.boltscience.com/pages/junker ... washer.htm
Robin
Pinzgauer 710K
MegaJolt ignition
Robin
Pinzgauer 710K
MegaJolt ignition
muffler flange nut
Very interesting video. What type of washer should be used in a similar situation? I trust welding is out?
There was so much exhaust putty on my fingers (well, latex gloves) when fitting the bolts that there is probably some in the threads which will act as a thread lock to an extent... I might get some lock nuts if they start coming loose
Robin
Pinzgauer 710K
MegaJolt ignition
Robin
Pinzgauer 710K
MegaJolt ignition
