Carbs freezing up - anyone else have this just for your info
Jerbear, I run here in Quebec in the minus 20 and 30 celcius and what I found is that if I want a good running Pinz in the cold you have to shut that front grill off. Mine is blocked all the way and it is going great with no oil in the filter or anywhere.
I did a nice snowstorm run lately and everything went fine
Denis
Denis
carbs
Blackstak,
There is an intake that has a thermostat in it for very cold places. I have seen this on some pinzies and it is in the parts manual. Mine is not equipped with one, just regular intake.
carbs
I have seen it in Group 1 35 in the parts manual. parts 81, 82, 83, 85, 86, 87, 88. (7121190802)
It replaces the stock one I have. 65 (7123190032/30)
It's available as a kit from SAV: http://www.pinzgauer.com/showdetails.ph ... 121195019/
I have it installed on mine and it did seem to make a difference.
'73 Swiss 710M
'73 Swiss 710M
carbs
Paul,
You are in a cold climate... like I am now. Haven't lived in snow since I was a lad in Ohio.
Was this a simple install? I am thinking about it. How does it affect summer operation?
Morris
Morris
I would rate it a simple installation. The most difficult part is drilling 2 holes in the air intake for the vacuum line fitting (item 92 on the Group 01-35 page). They do not provide a template for the location so some careful planning is in order.
The vacuum line (#91) connects at the same banjo fitting that the vacuum line for the distributor connects to, so you will need a Y or T fitting from your local auto parts store.
You'll probably also need 30-05-55 #7122190128/N, the hose that goes from the air intake to the heater valve, unless you already have one.
I don't think it affects summer operation at all since the thermostat just opens wide when it's warm, allowing air to flow directly in.
When I installed mine I wasn't able to do a direct comparison with/without because it wasn't cold enough but I do feel it was worth the investment.
'73 Swiss 710M
'73 Swiss 710M
After I saw Paul's, I got one of these too. I agree, it's easy to install. I got mine off Ebay, as Willy occasionally lists some of his stuff there, so I got a deal on it too.
IMHO, the truck seems to run a bit more smoothly when starting in cold weather. It didn't seem like a HUGE improvement, but it did seem better. It might prove to be more important to folks who drive in the cold more. Because Wis. uses salt on the roads, I don't drive it that often once snow flies.
Paul U.
ps, P.C., I'm always jealous of your nice clean engine bay/s!
Paul U.
SAV now has the kit listed on ebay:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 712wt_1101
Merry Christmas to All!
Paul C
Paul C
'73 Swiss 710M
'73 Swiss 710M
Well Dennis has finished the carbs and this is what he found.
Lots of resin build up so he had to soak them for four days. The floats were too low and the choke (because of the build up) were sticking and never went fully off.
So they are sending my carbs out next week so it will be good to get them back.
Anyway just the update - I will check into the pre=heater
Jer
Jer
