My engine has a twin-vee pulley on the front of it, which should come in useful should I decide to fit another alternator/power steering etc. - is this a standard fit and if so, why?
Can't get the pulley off, mind - handbrake isn't good enough to stop the vehicle rolling when I pull on the breaker bar. I even tried the old Land Rover trick of trying to undo it with the starter motor but that wasn't strong enough either... My air driven SIP 1/2" impact driver doesn't touch it
Twin vee pulley (and how to remove it?)
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
Robin;
Twin groove pully! Me want one! Seriously, can those be had for purchase?
When I removed the pully to install Hall Magnets for the FI project I used lots of WD40/Break Free, an industrial heat gun (big hair dryer) and patience. Once you remove the bolt then even more patience is required to pull the pully.
DO NOT stick a breaker bar through the openings on the pully an apply torque - you will break the cast iron pully. Then you will be sad and or mad.
712 M
I was bearing this in mind as I went to fetch my puller from the garage. Imagine my surprise to find that my pulley doesn't have holes in it (and fortunately it came off very easily by hand):Lisaspinz wrote: DO NOT stick a breaker bar through the openings on the pully an apply torque - you will break the cast iron pully
Robin
Pinzgauer 710K
MegaJolt ignition
Robin
Pinzgauer 710K
MegaJolt ignition
