I need a new muffler. I know. it's bellowing like a wounded buffalo. I'm all over that, but that's not what I'm asking about ... I'm getting exhaust smell in the cab. I'm concerned the heat exchanger is pulling the exhaust fumes in. i can't see how I could actually test to make sure the heat exchanger is intact or not.
any body got any ideas?
Jim
heater/heat exchanger leaking?
Re: heater/heat exchanger leaking?
Take off the heat exchanger plug up one end with a ball and blow some air in the other and see if it holds? Water might be fun to use too.
2X 712AMB Oakland, CA
- ScottishPinz
I would suggest as a minimum before taking anything apart, does the smell go away when the hot air input is off? If not then disconnect the hot air tube from the heat exchanger and plug it up as a final test before removing the whole lot and checking.
If the pipes are breached(leaking) you can make a sleeve with a piece of pipe slightly smaller in diameter to fit inside and weld up the ends
Much cheaper than replacing
Jim LaGuardia wrote:If the pipes are breached(leaking) you can make a sleeve with a piece of pipe slightly smaller in diameter to fit inside and weld up the ends
i thought of that. the heater hasn't worked very well over the years I've had it. i've been concerned I'd lose even more heating.
