Would anyone be so kind to list what to check for consistent backfiring? It just started within the last few weeks after running the truck hard in the sand. It feels weak in power and pops about a second after letting off the gas
Exhaust leak? Whats the best way to find a leak if its not visible? rev and carefully line up hand?
Coil failure?
Condenser failure?
Much appreciated!
Backfire check list?
- audiocontr
Re: Backfire check list?
Exhaust leak? Redneck check - pop a leather work glove on and with the engine on idle, use your hand to seal off the tailpipe. If the exhaust is good or even reasonable it'll try to stall out, if you have a leak it'll keep running and you'll hear a farting sound which makes it easier to track down the leak.
It aint what you drive, its the way that you drive it...
Take the air filter off and check nothing's got through into the carbs
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
- audiocontr
Found a nice rot hole on the passenger side of the can. Time to replace i guess
Since you are replacing, it would be good to know which muffler you choose and why. Not stock I presume?
Happy trails,
Morris
Happy trails,
Morris
After checking with Scott/Jim (thanks both for advice) - finally i got 304 stainless version of Hushpower II Muffler put on.. the CM-35 was leaking previously & so Andre had welded the leak last year..
happy with the hushpower II performance.. gives a sense of better throttle response (on 712 any little helps)
- only problem is that on revving the pinz sounds like a ferrari
{ hence noisier than the previous IMCO CM-35 }
PS. morris - chosen since 304 SS & 18" as opposed to CM-35 (16.5" ?)
- audiocontr
Could you please send me information of the muffler you used?
