Engine is hotter than normal, rough running.
Ok, not sure what the problem is, used to run great, but I do a lot of driving. Now it takes a long time to start hot or cold, and runs real rough. Also engine its putting of a lot more heat than normal. Strong smell of fuel too, and cuts out at low rpm. Any help? Also if there arete any pinz owners near new orleans, that'd where I am right now, if you'd be wiling to take a look. Thanks.
...and now the fun part.
1981 712 amb
1981 712 amb
Re: Engine is hotter than normal, rough running.
Short on oil?
Edit: Or air leak in carb?
According to the dipstick, its got plenty of oil, would an air leak, mean I need new gaskets?
1981 712 amb
1981 712 amb
and the last time it had a tune-up was?
- westernair
find a good air cooled vw mecanic and have then sync the carbs, check for a vacume leak and give it a tune up.
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
I've learned that you can't just drive a Pinzgauer day after day without fussing over it here and there. They take a lot of preventative maintenance, much different than a modern car...
Without tinkering, they will eventually stop running consistently, like yours has.
What's a good way to test for an air leak as mine is exhibiting similar symptoms?
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
Spray the carb area with WD-40 or similar while the engine runs. Small leaks will get plugged by the spray, and the engine operation should change. Pinpoint the location where the spray makes a difference, and that's likely your leak.
I'll try that - mine is only running on full choke and as a result, is popping/backfiring like a good 'un due to all the extra fuel. Might be the idle jets are blocked but if I ever get a day off work I'll give her a good going over
Robin
Pinzgauer 710K
MegaJolt ignition
Robin
Pinzgauer 710K
MegaJolt ignition
Usually if its running hot, and since you said its harder starting, then it may be running lean. So the above posts about a vacuum leak are right, or check the mixture settingwanderer wrote:Ok, not sure what the problem is, used to run great, but I do a lot of driving. Now it takes a long time to start hot or cold, and runs real rough. Also engine its putting of a lot more heat than normal. Strong smell of fuel too, and cuts out at low rpm. Any help? Also if there arete any pinz owners near new orleans, that'd where I am right now, if you'd be wiling to take a look. Thanks.
When it's idling, if you haven't tried this already, spray carb cleaner spray around the sides of the carb or where there are some vacuum lines. If the idle changes when spraying then you've hit the leak. Just what I would do
Don't forget to spray under the tin shielding to ck for leaks. Seen several cases of loose-broken intake manifolds.
Mark
Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
68 Haffy
Replaced both gaskets on the choke housings and it runs a lot better now. Still a bit rough - I'm wondering whether they could do with syncing. Spraying carb cleaner at it did the trick (WD40 didn't have any effect, even when I sprayed it right down the carbs - then again, this was when it was running on full choke, as it turns out)
Robin
Pinzgauer 710K
MegaJolt ignition
Robin
Pinzgauer 710K
MegaJolt ignition
Mine still wasn't running right but of course having it running on full choke for so long had fouled the plugs. Pulled them all out, cleaned them up and it's sweet as now
Robin
Pinzgauer 710K
MegaJolt ignition
Robin
Pinzgauer 710K
MegaJolt ignition
