Removing / Replacing Motor Mounts
Posted: Mon Aug 19, 2013 1:25 pm
by 19D20
I'm struggling to get the last (13-14mm) bolt on the passenger side motor mount that are blocked by the engine bracket . Any tips or secrets to achieving this ? Any other tips are greatly appreciated.
Thanks, Andrew
Re: Removing / Replacing Motor Mounts
Posted: Mon Aug 19, 2013 1:45 pm
by berger
19D20 wrote:I'm struggling to get the last (13-14mm) bolt on the passenger side motor mount that are blocked by the engine bracket . Any tips or secrets to achieving this ? Any other tips are greatly appreciated.
Thanks, Andrew
Andrew, did you read this thread? I know it is on sheared bolts, but I think the lift is the "trick."
http://www.real4x4forums.com/PinzgauerB ... otor+mount
Posted: Mon Aug 19, 2013 2:15 pm
by 19D20
No sir I did not. I did a search for motor mounts and missed that one.
So lift the engine after loosing all the other bolts-ha.
Thanks much.
Andrew
