Stuck Dizzy
Posted: Mon Sep 02, 2013 4:26 pm
Yes I searched and found this....
viewtopic.php?f=4&t=4120&hilit=stuck+distributor
Jim pretty much explains it clear as can be.
Mine is stuck. I can tap it lightly with a hammer left or right or if you prefer, clockwise-counterclockwise. It doesn't move much at all though and I am hesitant to tap it more than very lightly. I am also very hesitant to pry on it and we did try that a bit although not much. A new dizzy seems not available and I see no used ones out there in internet land too. So I really don't want to cause any damage. Apply penetrate, tap & pry seems to be the method? Any other solutions? What causes them to stick or seize like this? Simply corrosion? How much prying is to much before something will break? I am used to working on cast iron motors where everything is steel or cast. Which in turn can mean I am prone to do to much prying, beating, whatever on this alloy engine.
