#4 exhaust manifold is white
- McCall Pinz
I pulled the exhaust manifold today and was surprised to find the #4 pipe is white while the other three are black. Is white too lean? or is black too rich? Also, #4 is the one that had the leak. I'll post a pic later. Thanks for input.
eat, sleep, Pinzgauer
Re: #4 exhaust manifold is white
Others will have to comment on whether it's to lean or not. But I have noticed mine assume the color of whatever color mud I was in when they were hit with it. Then the color baked on. Odds are that pipe was a lot colder than the others and assumed a different color. That must have been a bad leak!
1974 Pinzgauer 710M
1990 Puch G Wagon 230 GE
1974 Pinzgauer 710M
Buzz he has the manifold removed and is looking at the inside of the exhaust ports.
In my opinion number 4 is running lean. Before replacing the manifold I would check the valve adjustment than do a compression test.
- McCall Pinz
- McCall Pinz
A quick search seems to suggest that the exhaust leak right at the head can cause a lean condition, but I'll pull the plugs to check.
Very possible, If the plugs are reasonably consistent all should be good.McCall Pinz wrote:A quick search seems to suggest that the exhaust leak right at the head can cause a lean condition, but I'll pull the plugs to check.
I knew that! I was just checking you guys!
1974 Pinzgauer 710M
1974 Pinzgauer 710M
Buzz wrote:I knew that! I was just checking you guys!
Ya right, and like there’s a snowball’s chance in Jacksonville that I’ll believe that..
than again I do remember it snowing in the ‘70’s when I was stationed at NAS JAX.
