top end work comp., exhaust work time. I have Questions!
Posted: Thu Feb 13, 2014 12:09 pm
On my previous post, I was at the beginning of this project. A big thank you to Jim, blackstack, and a few others for the tech. start. the eng. fired up no problem, choke linkage alittle sticky, idle and fuel rates still will need the fine tuning that I require. Now my new inquiry is about exhaust back-pressure and the use of after market mufflers. I know that there needs to be a sweet spot with the back pressure to obtain good torque, i.e. something for the motor to push against. To little, not enough power in the pull, to much the motor cant breath well enough to produce the power needed to supply the brute torque need to pull.
the pinz came in to our shop because the exhaust had been hung and pulled down. it also ran like a turd, E.I. running on 2 1\2 cly. spitn. and poppen, comp under 90 on the frist 3. Our exhaust tech pulled the heat exchange and muffler down and fabricated a y-pipe with an after market muffler.
I did the eng work after this, and during the process i wanted to do some thing different with the exhaust and to re-install the heat exchange. On a side note i tolled him not to cut down what he installed util i get the eng. running, well he did. I tried guiding him to build the flex update. im going to scrap out all hes done, done a little re-engineering, and do the exhaust my way.
so i would like every ones input on all of this. sorry the details are alittle long. i like jims post on the new mufler he is working on, and a big thank you to everyone. I have pics and vids of the whole process on my facebook, ( hillsidehorse@gmail.com) would like to post them on here.
