Name that oozing substance...
Posted: Tue May 27, 2014 12:33 pm
by nox654
Truck is (and was) running fine, however this ooze trail appeared after sitting for a week in moderately (85F) warm weather. I haven't had a chance to get into super research mode, and am still figuring out the truck as a whole in general, but I'm going to inexpertly hypothesize old hoses? Seems to be too much for general weeping. What I can see is a braided hose, covered (but not dripping) in a lighter color fluid. It doesn't smell like gasoline. The hose sits on top of the gas tank and runs aft, but where to I have yet to determine as I haven't pulled anything out yet.
Does anyone have an prior knowledge or insight with this particular issue?
Re: Name that oozing substance...
Posted: Tue May 27, 2014 12:56 pm
If you take a look behind the passenger seat at the gas tank fill pipe, you'll see a smaller metal pipe that comes off the rear of the fill pipe and goes down thru the floor. This is a vent pipe for the tank. The pipe connects to that hose covered in goo and the hose than goes back into the tank.
That hose is #14 on the following diagram:
- 01-50.jpg (120.39 KiB) Viewed 5585 times
Most likely that hose is old and is weeping gas slowly. The fumes probably just evaporated.
Posted: Tue May 27, 2014 2:49 pm
by Jack Russell Racing
I would *guess* it is the disintegration of your fuel filler hose, due to ethanol in the gas. We see it a lot in the Ferrari world, as these old rubber lines get destroyed by high ethanol content fuels --- especially when service stations switch to summer-blends.
Get it replaced. It is dangerous.
Posted: Tue May 27, 2014 2:56 pm
Had a similar problem. Had to drop the tank. Be sure to get the correct size hose, try one EI or SAV. Seriously doubt if Napa has the correct one.
Mine was abraded on one side from constant rubbing on the hole the tube goes through. Might want to put a grommet there when you replace the hose.
A tank full of petrol is heavy. Either run it out or drain it. Might take two people to drop that tank.
Posted: Tue May 27, 2014 4:51 pm
if it is oily, it is a leaking jack
Posted: Tue May 27, 2014 8:20 pm
If you drop the tank replace the two cork gaskets #5 in the drawing at the tanks mating surface for the fuel pickup tube and the fuel level sending unit. That's where mine was leaking and exhibiting the same appearance, I replaced all the fuel line going to the tank at the same time. The large fuel fill tube was fine on mine.
Posted: Tue May 27, 2014 8:27 pm
Jim LaGuardia wrote:if it is oily, it is a leaking jack
I remember that post a while back - oil and the odd drip and it ended up being the jack
On mobile so hard to search for that old thread
Posted: Tue May 27, 2014 9:15 pm
TechMOGogy wrote:Jim LaGuardia wrote:if it is oily, it is a leaking jack
viewtopic.php?f=9&t=7489&hilit=leak+jack
Posted: Tue May 27, 2014 9:19 pm
by nox654
Forgive my ignorance, jack for what exactly?
I think a tank drop is definitely in order at any rate. How hard of a task is this for one person (given an empty tank)? 1-day job at most? (fingers crossed...)
Posted: Tue May 27, 2014 9:41 pm
by Andre
[/quote]Forgive my ignorance, jack for what exactly?[/quote]
Are you serious? Please tell me your truck DIDN'T come with a hydraulic bottle jack that sits behind the passenger seat, next to the fuel neck, used to change out a flat.
Posted: Tue May 27, 2014 9:44 pm
Not a bad job, did mine with ~4 gallons in the tank. Used a floor jack with a piece of plywood about a foot square between the jack and the tank to hold the tank up while bolts were removed and to ease the tank down while removing the fill tube. used the jack to lift the tank back into place also. the only real pain is getting the fill tube back into place. A little grease helps to slip the tube back into place. Took me a couple of hours, was in no rush.
Posted: Tue May 27, 2014 9:59 pm
by nox654
Are you serious? Please tell me your truck DIDN'T come with a hydraulic bottle jack that sits behind the passenger seat, next to the fuel neck, used to change out a flat.[/quote]
No, no it's there...AND LOOKS LIKE IT"S BEEN LEAKING. Son of a... I cleaned everything out, put the jack on some clean towels, and will wait and see what everything does over the next couple days. Fluid color did look awfully similar to what I wiped off of the outside.
Posted: Wed May 28, 2014 6:43 am
by berger
Andre wrote:Forgive my ignorance, jack for what exactly?
It is possible. My truck came from a reputable dealer and it didn't have the OEM jack. He swapped in a crappy jack that doesn't even reach the axle when fully extended.
Posted: Wed May 28, 2014 8:37 am
by Andre
I hate when "reputable dealers" do things like sell trucks that have been stripped of all the tooling and kit. I feel the same about motorcycle shops that steel the tool kits out of the bikes when they come through.
My sympathies are with you.
