What is the "correct" fuel pressure?
Posted: Sun Nov 02, 2014 10:08 am
What is the correct fuel pressure I should be measuring at the carb inlets? The service manual specified minimum fuel pump performance at 4000 rpm as 24 liters (per hour, I'm assuming) and 0.3 bar pressure (4.3 psi). What pressure do you measure with a properly working pump under normal conditions?
I intend to replace the mechanical pump with an electric pump and adjustable regulator. I need a pressure to set things up.
Thanks!
Thanks!
