Steering Box Drain
SAM. C.
Steering Box Drain
Post by SAM. C. »
Greetings Gents
Is there a drain plug for the steering box oil?
I cant seem to see one. All I can see is the little square filler on the top.
Sam
spandit
Re: Steering Box Drain
Post by spandit »
Mine drips out of the seal at the bottom... don't think there is a proper drain plug, though. There are 2 bits you have to fill up - one of mine has the square plug, the other one just has a plastic cap
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
westernair
Post by westernair »
I changed my fluids about 4 months ago. I sucked it out of my stearing box with a brake vacuum pump.
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
SAM. C.
Post by SAM. C. »
Thanks Guys
I thought there wasnt a specific drain.
Spandit do you mean the little red plastic cap above the square drive?
Is that a filler for a sepearate reservoir? I didnt realise there were 2.
Sam
spandit
Post by spandit »
SAM. C. wrote:Thanks Guys
Sam
I think it a separate filler - could be wrong
Robin
Pinzgauer 710K
MegaJolt ignition
cronapress
Post by cronapress »
I quote from the Handbook: "FILLING UP OIL IN THE STEERING BOX"
" Remove plastic plug (fig.123/1) and top up with gear oil SAE 80
until oil flows out from the opening. After removing the screw
(fig. 123/2) top up this bore too until oil flows out of the
opening."
An accompanying picture shows 123/1 is the red plastic cap. 123/2 is the square headed filler screw. It would appear there are two separate chambers within (?). Can't see any mention of a drain at all.
Hope this helps.
Mike 712M
Had one out for a rebuild a while back and there are no drains.
As cronapress said, there are 2 separate chambers that need to be filled.
SAM. C.
Post by SAM. C. »
Thanks guys
As usual this is the place to come for good advice.
Sam
