Transmission Input shaft
rospaw
Post by rospaw »
Trying to get my parts ordered. I have to change out the input shaft on the transmission due to a grove that has warn in it. Noticed it when i pulled the clutch. When changing this shaft what other parts (gaskets, seals ect) do i need? Thank ahead...... Shawn
74 710 RAGTOP
Jeeps 74,86,92
max iv 6x6
Excursion
Ford f350 D
Re: Transmission Input shaft
you might be able to use a repair sleeve if proper size is avalible.
http://www.vsm.skf.com/en-US/HeavyDuty/ ... leeve.aspx
Ed
pinzdriver
Post by pinzdriver »
You will have to split the trany case to replace the input shaft and take it from me you dont want to open up that can of worms. :oops:
tony in az 73 pinz 6X6
pinzdoctor is the name,pinz repair is the game!
cruzoropeza
Post by cruzoropeza »
been there take it a step at a time! your lucky you know where the problem is, one of my transfer gave out in my pinz and i could pin point where the problem was i ended up taking it all apart to find the problem!
at this point a started getting worried if i was going t be able to remember how to put it all back together!
rospaw
Post by rospaw »
cruzoropeza wrote:been there take it a step at a time! your lucky you know where the problem is, one of my transfer gave out in my pinz and i could pin point where the problem was i ended up taking it all apart to find the problem!
Man that looks like a project from .....! :lol: I don't mind spilting the case (been in a tranny or two) but sure would like to know gaskets, seals ect that i will need and a few i might need. When doing it i would like to tear down and build it back in the same eve. Keeps thing fresh on where they go-went-might fit :roll:
74 710 RAGTOP
Jeeps 74,86,92
max iv 6x6
Excursion
Ford f350 D
rospaw I sent you a PM check your messages
