Weird noise?!?
cruzoropeza
Weird noise?!?
Post by cruzoropeza »
Ok guys I need help when I turn on my pinz I put it in neutral and release the clutch I hear a weird humming noise? What can that be it's not a very loud noise but it's there I'm puzzled
Thanks for your help!
cruzoropeza
Re: Weird noise?!?
i crossed a large body of water in the week end if that gives any help? im thinking something is going on in the clutch region hopefully some one can give me some suggestions
cruzoropeza
Re: Weird noise?!?
Ok no I'm hearing almost the same low wining noise when I start taking off. Ahhhhhhh has anyone encounter anything like this?!?!!!!
Re: Weird noise?!?
Not a clue, enough variables I’d just be guessing. May want to check transmission fluid level just to be on the safe side, stick a finger in and check for any evidence of water contamination. Hopefully someone can come up with a better answer.
Bulldawg
Re: Weird noise?!?
Post by Bulldawg »
Just a thought. Did you push the clutch in while in deep water? This can allow crud to coat the clutch plates. If you are lucky you can rinse the crud out or maybe it will clean out on it's own.
cruzoropeza
Re: Weird noise?!?
Yes I did put clutch in I'll check that out thanks!
