Anyway, purpose of this thread is to solicit guidance & advice in how to get access to the clutch & replace the most likely worn-out parts/pieces. In my case, I intend to start with replacing the pressure plate and disc (hoping that'll do it). I reviewed the tips found here: viewtopic.php?f=13&t=5615&hilit=clutch Consulted my brother the far-away mechanic & decided to start work today.
Bad news is I have yet to get past step 1 in the repair manual: "remove the gear box". I thought things were actually going quite well (removed all parts, bolts pretty easily) & thought I was ready to yank the gear box out. In fact, after I got the jack in place, removed the last, loosened nut, & returned my attention to the bell housing area I noticed it had already separated on its own (and lots of nice clutch "dust" dumped out onto the grnd). "Freakin awesome...this is going to be easy to separate from the bell housing" - I thought.
Unfortunately, I cannot separate the very top portion of the bell housing. It's stuck; I'm stuck. I believe I have all the applicable nuts off; the clutch fork is disconnected; I have a new reduction gear starter, so no interference there. I even took off the nuts that secure what I think is a "clutch slave cylinder" (above the starter, see picture) and the small black plate mounted behind the cylinder that exposes what I would call a "push-rod" that goes into the slave cylinder thru a rubber sleeve). I am ASSUMING there is nothing to disassemble - that the push-rod simply unseats itself from the slave cylinder as you pull away the gear box from the bell housing.
Yes, I have used a hammer & pry bar. I have tried wiggling the gear box back and forth. I have tried jacking it up & lowering it. I even removed the jack and let the gear box dangle on it's own thinking maybe the weight would pop it free at the top - no joy. That very top part just doesn't want to let go.
Perhaps I just need to get a bigger pry bar but before I really go nuts beating the crap out of it, I wanted to check in with you experts to get your thoughts. Do I, in fact, just need to work harder at wiggling/beating the gear box until it gives way? Or have I missed disconnecting something (slave cylinder/push-rod?)?
Hopefully, the pictures here will help you help me:
