Peter,
You're pretty brave putting your hands iinto that goo! With a little radiation thrown in, you may turn into Swamp Thing.
Diff leaks? (visual included)
- David Dunn
Re: Diff leaks? (visual included)
Well my hands do glow at night now, Dave, but it's very handy when working on the Pinny in low light
http://www.ozpinz.com
Thanks Profpinz for the precision. Too bad to loose such a brilliant mecanic just for years of undermaintenance...
And as you said, be aware of boot!
- David Dunn
Well Peter, you may want to see a doctor when your shaving stubble is moss and your ankles and wrists develop portals
But the later might be a good thing for those hard to reach places on the Pinz.
You guys are freaking me out.
I have changed oil in everything, it was dark but not goo. How do you know without a complete tear-down?
You can have a look through oil change plugs. Use a flash light to see clear.
when you got all that apart do the seal to under # 37martinlbb wrote:Thanks for your feedbacks!
OK for o-ring, I'll do it.
For your cork, I got it: this is part number 900.3139, called "Plug" (french translation is closer to cork word).
This is part number 19 on this close-up.
Thanks all for your help, I appreciate
Well, everything is rebuild up. I changed all o'ring aand gaskets. Works wonderfull now
I have the sudden compelling urge to change all of my fluids......
