wheel dimensions
wheel dimensions
Can anyone out there give me the specifications on a 710 / 712 wheel? Specifically I would like to know how wide in inches, the bolt pattern, offset etc. etc. etc.
Thanks!
Thanks!
1974 712M - sold
1973 710M - sold
1974 712M - sold
1973 710M - sold
- GenevaPinz
http://real4x4forums.com/PinzgauerBBS/v ... lt+pattern
I think the stock wheels' width is 6.5 inches.
I hope this helps
I hope this helps
Jan
'72 Pinzgauer 710M
'72 Pinzgauer 710M
Thanks Jan. I was looking for these less obvious specifications.
David
David
1974 712M - sold
1973 710M - sold
1974 712M - sold
1973 710M - sold
Re: wheel dimensions
David, maybe this is the info you need.
Wheel Bolt pattern:
5 on 160mm (6.3"). Back spacing is 6 5/8"
Wheel Bolt pattern:
- GenevaPinz
I like your sense of humorBulldawg wrote:David, maybe this is the info you need.
Wheel Bolt pattern:
Jan
'72 Pinzgauer 710M
'72 Pinzgauer 710M
Thanks guys. I'm sort of off again, on again with finding some reasonably priced alloy wheels to replace the skinny stock ones so I wanted to know precisely what I was looking for, dimensions wise.
David
David
1974 712M - sold
1973 710M - sold
1974 712M - sold
1973 710M - sold
Skinny is good except on a beach or in the dunes. I come from the land of swamp & muskeg ... big fat tires just cause problems in soft goo; kinda like walking in rubber boots and then wading into a 2 ft mud hole http://real4x4forums.com/PinzgauerBBS/p ... =13&t=6027#.
Tall and skinny cuts through mud & snow nicely, and when you're really stuck there is a lot less drag pull them out of a hole.
- westernair
Has anyone ever modified their pinz to accept a different bolt pattern, one more common?
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
Check with Stockton Wheel (http://www.stocktonwheel.com)
They have done Pinz work in the past.
Stockton Wheel Service
648 W. Fremont St.
Stockton, CA 95203
1-800-395-9433
-or-
209.464.7771
Fax: 209.464.4725
648 W. Fremont St.
Stockton, CA 95203
1-800-395-9433
-or-
209.464.7771
Fax: 209.464.4725
Thomas E.
Sonora, CA
712 Camper
Sonora, CA
712 Camper
David, what ever you get be sure to paint them white to match your Pinz.
See you at Creek Side on the 25th.
