wheel dimensions
Posted: Thu Jan 06, 2011 4:12 pm
by texas pinzgauer
Can anyone out there give me the specifications on a 710 / 712 wheel? Specifically I would like to know how wide in inches, the bolt pattern, offset etc. etc. etc.
Thanks!
Posted: Thu Jan 20, 2011 3:26 pm
by GenevaPinz
http://real4x4forums.com/PinzgauerBBS/v ... lt+pattern
I think the stock wheels' width is 6.5 inches.
I hope this helps :wink:
Posted: Thu Jan 20, 2011 4:52 pm
by texas pinzgauer
Thanks Jan. I was looking for these less obvious specifications.
David
Re: wheel dimensions
Posted: Thu Jun 02, 2011 12:44 am
by Bulldawg
David, maybe this is the info you need.
Wheel Bolt pattern:
5 on 160mm (6.3"). Back spacing is 6 5/8"
Posted: Thu Jun 02, 2011 6:42 am
by GenevaPinz
Bulldawg wrote:David, maybe this is the info you need.
Wheel Bolt pattern:
I like your sense of humor :wink:
Posted: Sat Jun 04, 2011 12:03 pm
by texas pinzgauer
Thanks guys. I'm sort of off again, on again with finding some reasonably priced alloy wheels to replace the skinny stock ones so I wanted to know precisely what I was looking for, dimensions wise.
David
Posted: Sat Jun 04, 2011 10:50 pm
by Winter Beater
Skinny is good except on a beach or in the dunes. I come from the land of swamp & muskeg ... big fat tires just cause problems in soft goo; kinda like walking in rubber boots and then wading into a 2 ft mud hole http://real4x4forums.com/PinzgauerBBS/p ... =13&t=6027#.
Tall and skinny cuts through mud & snow nicely, and when you're really stuck there is a lot less drag pull them out of a hole.
Posted: Sun Jun 05, 2011 2:09 am
by westernair
Has anyone ever modified their pinz to accept a different bolt pattern, one more common?
Posted: Sun Jun 05, 2011 3:51 pm
by Thomas-E
Check with Stockton Wheel (http://www.stocktonwheel.com)
They have done Pinz work in the past.
Stockton Wheel Service
648 W. Fremont St.
Stockton, CA 95203
1-800-395-9433
-or-
209.464.7771
Fax: 209.464.4725
Posted: Sun Jun 05, 2011 10:10 pm
by Bulldawg
David, what ever you get be sure to paint them white to match your Pinz.
See you at Creek Side on the 25th.
