Chirping Noise
Posted: Fri Feb 17, 2012 12:04 pm
by Stekay
I occasionally get a chirping noise that turns into a screech that seems to be coming from the transfer case area or maybe the right rear hub. Anyone have any thoughts on this? I'll be changing all fluids this weekend and will check the wheel bearings while I'm at it. It sounds very much like a slipping belt, which I did change last weekend and will check tension on again as they do tend to stretch initially. I'll update either way. Thanks -Steve
Re: Chirping Noise
Posted: Fri Feb 17, 2012 3:18 pm
by bonefish635
It's not by any chance a bird's nest?
That would certainly explain the chirping and I could well imagine circumstances during driving which would so alarm a clutch of young birds that they might begin to screech.
Hope that's helpful.
T
Re: Chirping Noise
Posted: Fri Feb 17, 2012 9:22 pm
by Stekay
ummm no
Re: Chirping Noise
Posted: Sun Feb 19, 2012 7:28 pm
by bernhard
sounds like a clutch throwout bearing to me......
Re: Chirping Noise
Posted: Mon Feb 20, 2012 6:58 am
by Stekay
Ya know, now that you mention it, it does sound like that kind of noise, but would that happen with the clutch engaged?
I seem to get it more when getting on the power and when starting out cold. I even thought it might be a harmonic setting something off but, as stated earlier, it seems to be from that right rear although on a Pinz that could emanate from anywhere. I'll play with the clutch idea... Thanks
