another mystery leak
Posted: Wed Sep 19, 2012 1:49 pm
Noticed a leak today. On the inward face of one of the rear hubs, vertically aligned with and down from the wheel centre there is a small hole (not either of the portal hub fill/drain holes) and it is weeping clean oil of some sort. The hole is maybe 5mm or 1/5" across and looks like it is supposed to be there. None of the other hubs is even showing signs of moisture at that point. Niether of the fill/drain bolts is leaking at all.
Any idea what would leak through there? My own fixing skills pretty much peaked with replacing the starter motor. If I take the hub apart I'm asking for trouble.
I can take photos if that would help diagnosis.
Tony
Tony
