Baffled by clutch issue
Posted: Tue Nov 20, 2012 10:17 pm
I have a weird friggin clutch issue that I just can't figure out, after much hypothesizing.
What I have, but only on occasion, is dead travel in the first few inches of pedal travel. The pedal will only have the resistance of the spring in the first part of the travel, then it feels completely normal as its hit resistance. When it does this, the clutch won't release until the pedal is very near the floor. I was fearful last time that I wouldn't be able to shift gears if it went any further. I had no play left when at its worst.
The physical clutch feels completely normal itself. Also the fluid level hasn't changed at all. No leaks. No weird noises. I noticed this the first time, and at its worst, when at Mogfest this year after a mild trail ride. I think it was gradual because it didnt occur to me until getting back to camp. I just took it for a test drive and its back to normal. It has been sitting a couple weeks. I drove it 15 minutes and the pedal didnt vary at all this time.... it feels like it should with hyd resistance within the first 1/2" of travel.
The few guess have been:
AIR, but I doubt this as I've dealt with air many times and this seems very different than any air issue I ever heard of.
WRONG CLUTCH PARTS, two people guess this one but I think if I had the wrong clutch it would never feel normal and Id have other issues.
HEAT- someone said heat may be affecting the hyd line and changing the humidity levels in the fluid as it likely has some water in it. I highly doubt this one but Im open to anything at this point.
The old "replace parts till its fixed" isn't an option for me as its probably $800 to replace everything. Other guesses? And yes, this is on a Steyr, just not a Pinz, but its the same basic set-up.
