Page 1 of 3
Need execution 1 bolt, 10mx70...FOUND
Posted: Tue Jun 11, 2013 6:54 am
by stiffler4444
Hi all,
So the factory no longer produces the execution #1 10mx70 cheese head bolt. I can get the 10mx80 from Scott, but then I'd have to shorten it. Anybody out there got one laying around? Probably not, just thought I'd ask.
tx Dave
Re: Need execution 1 bolt, 10mx70...anybody?
Posted: Tue Jun 11, 2013 7:31 am
by berger
stiffler4444 wrote:Hi all,
tx Dave
Did you check with SAV?
Do you have a pic of the bolt head? I am going to check a few places....
Posted: Tue Jun 11, 2013 7:55 am
by stiffler4444
Sav only seems to have the 10mx80 in their parts catalogue online. I will also check with Karl at PC, but has to be OEM or similar high grade 12.9 bolt. Pic attached.
tx Dave
Posted: Tue Jun 11, 2013 8:10 am
by berger
Allen head? How long is the shoulder etc? I have a great fastener shop near me.
Sent from my Mobile
Posted: Tue Jun 11, 2013 8:39 am
by mopar
Check with Ralph at BelMetric he may be able to get it for you.
https://www.belmetric.com/
Posted: Tue Jun 11, 2013 9:11 am
stiffler4444 wrote:Sav only seems to have the 10mx80 in their parts catalogue online. I will also check with Karl at PC, but has to be OEM or similar high grade 12.9 bolt. Pic attached.
tx Dave
Maybe this ?:
http://www.mcmaster.com/#socket-head-cap-screws/=n5a813 (Item # 91290A542)
Also I would definitely give Sarah at SAV a call since they often have items in stock that are not on their website.
Posted: Tue Jun 11, 2013 9:31 am
by stiffler4444
berger wrote:Allen head? How long is the shoulder etc? I have a great fastener shop near me.
Sent from my Mobile
Yes, it's an allen head. I don't have it in front of me (well, I only have half of it anyways, the rest is stuck in the diff bolt!)....if I can't find an OEM, I will have to look into a fasterner place.
Posted: Tue Jun 11, 2013 9:32 am
by stiffler4444
Will check them out if I cannot find OEM.
thanks!
Posted: Tue Jun 11, 2013 9:33 am
by stiffler4444
pcolette wrote:stiffler4444 wrote:Sav only seems to have the 10mx80 in their parts catalogue online. I will also check with Karl at PC, but has to be OEM or similar high grade 12.9 bolt. Pic attached.
tx Dave
Maybe this ?:
Ya, I'll give SAV a call as well. Just waiting to hear back from Karl Portman, as he's pretty close.
thanks guys!
Posted: Tue Jun 11, 2013 9:35 am
by berger
tx Dave
Maybe this ?:
Good find Paul! I was searching without luck! Now to make sure the pitch is 1.5 and not 1.
Metric Class 12.9 Alloy Steel
Partially Threaded
Made from a high-strength steel alloy, these are the metric versions of our popular inch size alloy steel screws. Screw length is measured from under the head.
Standard thread and fine thread screws have a dark surface color as a result of heat treatment. They have a Class 5g6g thread fit, a minimum Rockwell hardness of C39, and minimum tensile strength of 174,000 psi. Dimensions meet DIN 912/ISO 4762. Fine thread screws allow precision adjustment.
High-visibility metric blue screws have a distinctive blue coating that makes them easy to distinguish from inch sizes. They meet ASTM A574M (similar to DIN 912 and ISO 4762) and ANSI/ASME B18.3.1M. All have a Class 4g6g thread fit, a minimum Rockwell hardness of C38, and minimum tensile strength of 176,900 psi.
Lg.,mm Pkg.Qty. Per Pkg.
Standard Thread—Black
M10—Pitch: 1.5 mm
70 10 91290A542 $5.01
Standard Thread—High-Visibility Metric Blue
M10—Pitch: 1.5 mm
70 10 91303A279 9.33
Posted: Tue Jun 11, 2013 9:39 am
by stiffler4444
Ya, that's probably the winner there !! I was having trouble finding one that wasn't somewhere in China still..........
Posted: Tue Jun 11, 2013 9:40 am
by berger
stiffler4444 wrote:Ya, that's probably the winner there !! I was having trouble finding one that wasn't somewhere in China still..........
I will head to my local shop at lunch and see if they have any on "the wall!"
Posted: Tue Jun 11, 2013 9:45 am
by stiffler4444
berger wrote:stiffler4444 wrote:Ya, that's probably the winner there !! I was having trouble finding one that wasn't somewhere in China still..........
Thanks! I see these McMaster Carr ones are a whopping $5 for 10.
Posted: Tue Jun 11, 2013 9:58 am
by berger
stiffler4444 wrote:berger wrote:stiffler4444 wrote:Ya, that's probably the winner there !! I was having trouble finding one that wasn't somewhere in China still..........
Ya, but sometimes they won't ship to Canada. I wanted a special Lube (Krytox) for my Ural Alt bearings, and I had to ship it to a friend in the US. They would only deal with companies and not individuals in Canada....at that time.
Good to have a local resource too....just in case!
Posted: Tue Jun 11, 2013 10:30 am
by berger
Some good news. My local shop carries the bolt type, but one size to small. They can order the one you want, so I am sure a good Fastener shop near you can do the same. You just need to verify the thread pitch.
- ImageUploadedByTapatalk1370964642.182659.jpg (130.6 KiB) Viewed 5758 times
Sent from my Mobile
