4wd and locker LIGHTS ?
norcal pinz
Post by norcal pinz »
my lockers and 4wd is engaging but the lights on the dash don't come on like their supposed to :
I checked for power at the lights and its there ,when i give it ground they come on
what should i check next ??????????? thanks......
710M 1972
710k 1974
Re: 4wd and locker LIGHTS ?
Look for the switch cover (03-25-02) that is opposite each of the hydraulic locker slave cylinders. The diagram of Group 03-25 shows them fairly clearly. Coming out of each cover is the wire from the switch with a spade connector to the wiring harness. These connectors often get corroded and filled with dirt. A good cleaning/scrapping often solves the problem you're having. The connectors are not the easiest to get at so someone with small hands might help.
norcal pinz
i cleaned all the connectors already its not that, but thanks.
Any other ideas anybody ?
710M 1972
710k 1974
It's not likely all 3 switches are bad so how about the connector that all 3 grounds run thru? Any chance that's not fully seated?
Look for dirty ground connection at switch covers. All the switch does is provide the ground circuit for the lights , double check the 3 wire connector(ground each terminal to test), there is one more connector with the 3 locker circuits under the dash . If you ground each wire at the switch cover and all 3 lights come on, then your switches are most likely dirty or the floating actuating pins are missing.
norcal pinz
im in the middle of it now it appears that the wires inside the switch cover are old and weren't making a good ground, so im going to replace all the short wires inside the covers with new connectors. thanks Jim and folks !
710M 1972
710k 1974
norcal pinz
i got both locker lights to work but not the 4wd light but now i know how everything works so it shouldn't be too hard to fix that one. :lol:
710M 1972
710k 1974
