Been off the board for awhile, but I need help on this. My 712's blinker switch has a broken wire in it that I can't get soldered back on. So, I took the blinker assembly off of my 710 and thought it would just plug straight in. It plugged in fine, but still no blinkers in the rear. Could it be the light relay? If so, where is it and what does it look like.
Blinker problem
Re: Blinker problem
The light relay is just to the right of your turn signal flasher on the panel to the left and below of the dash. It looks like a small silver rectangular box. The turn signal wiring also is routed thru your hazard warning switch on the same panel.
Hopefully you've got a schematic and can track down the wire for the rear lights.
Good luck.
Good luck.
Re: Blinker problem
Re: Blinker problem
Thanks, guys. Yes I have the schematic, had it blown up to poster size. It has to wait now until I get back home again. Hopefully it will be a little warmer the next time I get home. It has been awfully cold here, for Southwest Texas, the last few days.
